Type 3 and 4
0 Members and 1 Guest are viewing this topic. Read 5853 times.
Louis O
Type 3 and 4
« on: 28 Jan 2011, 08:09 pm »
Hi All,
Working on getting finished pictures up for the T3 and T4
Prototypes and testing is all done.
The T3 is the Sub. It's 11 x 11.5 x 18 tall. Bottom firing driver (my own) and sealed cabinet.
The footprint in the line remains constant. This means that the option of stacking Type 1's on top of Type 3's is doable. I would recommend placing Granite in between.
If you order one sub and another at a later date, stacking is an option.
The Type 4 looks exactly like the Type 2 floorstander. The cabinet is chambered. Top is a Type 1 and bottom is a Type 3. The sub sat is housed in one cabinet. The Type 4 is all set up with the wiring and it's plug and play.
Louis
ashok
Re: Type 3 and 4
« Reply #1 on: 15 Feb 2011, 11:06 am »
Hi Louis,
About the Type 4, is it correct to assume that the sub is powered via speaker-level inputs?
That is, the sub derives its input signal from the power amplifier's speaker outputs (which also power the Type 1 driver in the cabinet).
Is there an option to drive the sub with preamp line-out signals?
Ashok
Louis O
Re: Type 3 and 4
« Reply #2 on: 17 Feb 2011, 02:53 am »
Hi Ashok,
Thanks and you are correct. I set the system up so all you would need to do is connect from the amp normally.
There is an option to use pre out as well.
I do prefer the speaker level.
Thanks again,
Louis
