Bryston bp6 or bp25
0 Members and 1 Guest are viewing this topic. Read 23234 times.
vegasdave
Re: Bryston bp6 or bp25
« Reply #20 on: 26 Jan 2011, 10:33 pm »
Well, you, like Anonamerat appear as if you have nothing better to do. The proof is in your posts.
1ZIP
« Reply #21 on: 26 Jan 2011, 10:56 pm »
 :sleep:
vegasdave
« Reply #22 on: 26 Jan 2011, 11:05 pm »
JBLMVBC
« Reply #23 on: 27 Jan 2011, 01:54 am »
rob80b, thank you for your informative posts.
I had the chance to compare the BP25 with the BP 26 and stayed with my 25 for the 26 treble sounded a tad too present for my taste. Perhaps the unit needed more time to open up. I had a discussion with James about this and he stated the 26 was a 25 under a new shell and with minor adjustements, an evolution more than a revolution. I suspect that some incremental change might have been targeting low sensitivity HF drivers. However I kept the MPS-2 as it provided unflinching power to the unit. I do not pretend this was as rigourous, scientific test as it can be but that's my experience. 8)
For those who cannot afford a BP25/26 nor need the extra connectivity.
The BP26 is a BP25 but with the implementaion of a beefier external power supply to power additional devices, I believe there were also a few changes in some components, which is common for Bryston as they will implement a better componet in the circuit as  they become availabe.
Robert
rob80b
« Reply #24 on: 27 Jan 2011, 02:34 am »
Although we've strayed a bit from the OP's original inquiry, I had been tempted to try the MPS-2 with the BP25, I've read somewhere but cannot track down the source that the MPS-2 was more or less just housing four individual power supplies similar to the MPS-1 so I did not see the benefit.
Maybe James can chime in on that one.
Robert
werd
« Reply #25 on: 27 Jan 2011, 03:10 am »
The mps2 is more relaxed but seems to also rock out way better. Its twice the power supply as the mps1. I owned both, at the same time, for years.....lol
rob80b
« Reply #26 on: 27 Jan 2011, 03:22 am »
Hi Werd
It's the one you had for sale awhile back which was the temptation. :D
Robert
redbook
  • the music is the blood...........
« Reply #27 on: 27 Jan 2011, 03:23 am »
So the mps-2 has greater current?   :scratch:
werd
« Reply #28 on: 27 Jan 2011, 03:28 am »
Hi Werd
Robert
I was goin to lend it to you if the guy who was interested in it  hadnt bought it.  He bought my bp25 a week later too..... Go get the mps2  or go get a Torus. The Torus shrinks the gap between the two power supplies significantly.  I do think the mps2 is just a better bandaid for lousy outlet voltage than the mps1.
werd
« Reply #29 on: 27 Jan 2011, 03:33 am »
Yes its just a better interface between the wall and preamp. I would say it stores more energy.
