Need help on Octal Cornet assembly
0 Members and 1 Guest are viewing this topic. Read 1584 times.
library
« on: 19 Mar 2004, 04:20 pm »
Hello, Everybody
Today I just finished Octal cornet assembly. The cornet works 1/2. Left channel works OK but right channel does not sound even a noise. There is no hum at all on both channels.
I found the output + happened shorted by chassis, and I insulated that. But the right channel is not work at all.
Here are the measurements of plate voltages.
Pin#        2         5
V1 298       160
V2 315       313
V3 314       314
I think the shortage might kill a capacitor. Which capacitor I have to check for this shortage?  :bawl:
I checked the voltages from tube pins. Right and left voltages are almost same. I guess tubes and adjacent passives work fine, but cannot track down the reason yet. Does the shortage harm any tubes?
Please, help.
- lib
ps. I used cement resistors for R18 since I cannot get better one with 5w. Is it critical to sonotiry?
hagtech
« Reply #1 on: 20 Mar 2004, 05:13 am »
The plate voltage at V2 is wrong.  Should be about the same as V1.  My guess is that R5 is wrong value.
jh :|
library
Thanks, Jim
« Reply #2 on: 20 Mar 2004, 04:59 pm »
Thanks, Jim. It was soldering problem. My bad fingers...
