0 Members and 1 Guest are viewing this topic. Read 23992 times.
Get the latest version, 10.6 and it will install on a clean system without issue. No need to install an older version first.
Do I need to worry about the quality of the iTunes as a music player if all music is sent to a touch? In that case isn't the touch the player? I believe iTunes can handle 24/96 output to the touch?Thanks
Ok.....so the music and playbqck quality is better than itunes, but how do you control it? I run a headless Mac Mini controlled with an ipad. Can you run either using the Remote app or something similar?
