Type 2
0 Members and 1 Guest are viewing this topic. Read 11489 times.
Louis O
Type 2
« on: 23 Jan 2011, 11:25 pm »
Hi All,
The type 2 is the Floorstanding Hoyt-Bedford model.
Prices start at $1350 a pair and includes Cherry or Quartered Maple as standard finishes. All the Omega Finishes are available at a $300 option.
The Driver is the Hoyt-Bedford type 1.
This is an all new driver. It's an 8" dual cone and shares the whizzer from the ALN8Omega Alnico driver.
Ferrite motor with wood damping cover.
Extremely fast and articulate.
97dB efficiency
8 Ohm impedance
Type 2 features
Designed and built in house.
3/4" soft wood MDF for stability and 1/4" Hardwood MDF lamination on front and back
Ladder bracing with rear wall diffuser
Omega damping throughout.
Inset driver and attached with 8 brass machine screws and zinc inserts.
3" flared Prescision Port.
System can be run sealed or vented.
Vampire multiway binding posts
Triple lead internal wiring. 2 positive and 1 negative
Best quality wood veneers used on all panels.
Phenolic sheet between MDF and Veneer
Magnet Grills.
10 Year warranty.
Size: 40" tall x 11" wide x 11.5" Deep
« Last Edit: 26 Jan 2011, 12:19 am by Louis O »
sugbob21
Re: Type 2
« Reply #1 on: 25 Jan 2011, 12:50 pm »
Hi Louis
what would the frequency ranges be on  the new line ?
bronal
Re: Type 2
« Reply #2 on: 25 Jan 2011, 10:12 pm »
According to what I've been told:
Vented - 38Hz to 18KHz
Sealed - 50Hz to 18KHz.
Louis O
Re: Type 2
« Reply #3 on: 26 Jan 2011, 12:19 am »
Thanks Bronal. You are correct.
These make bass and quality bass at that.
Louis
Louis O
Re: Type 2
« Reply #4 on: 26 Jan 2011, 12:21 am »
Part of the warranty includes a set of drivers.
First set that are damaged or blown up, pushed in, whatever are on me.
I want everybody to play them without worry like I do. Play them loud and have fun.
Louis
doctorcilantro
Re: Type 2
« Reply #5 on: 26 Jan 2011, 07:09 pm »
They look great Louis, hats off!
Louis O
Re: Type 2
« Reply #6 on: 27 Jan 2011, 11:24 pm »
Hi doctorcilantro,
Many thanks and they look so good in person.
Getting better with the camera.
Thanks again,
Louis
markm1111
Re: Type 2
« Reply #7 on: 30 Jan 2011, 11:31 am »
I assume these are bottom ported similar to your Omega XRS speakers? Does that mean they are fairly easy to place in rooms, even close to walls?
AudioAddiction
Re: Type 2
« Reply #8 on: 30 Jan 2011, 11:52 pm »
markm1111 - Yes these are bottom ported.  Very room friendly.  I've put some of the Omega's in some very difficult rooms with great success.
Louis O
Re: Type 2
« Reply #9 on: 1 Feb 2011, 04:06 am »
Hi markm1111,
AudioAddiction is right and the speakers are bottom ported. They can also be configured in sealed or vented modes. This also helps with room placement.
Louis
johnnydarko
Re: Type 2
« Reply #10 on: 24 Apr 2011, 12:44 pm »
I'm thoroughly looking forward to some quality time with the Type IIs.   :D
Louis O
Re: Type 2
« Reply #11 on: 28 Apr 2011, 09:45 pm »
Hi johnnydarko,
Awesome and they are coming along. Can you send an email need to talk about finishes.
Louis
johnnydarko
Re: Type 2
« Reply #12 on: 29 Apr 2011, 07:35 am »
Hi johnnydarko,
Louis
Email sent!   :thumb:
Louis O
Re: Type 2
« Reply #13 on: 29 Apr 2011, 09:02 pm »
awesome thanks
