0 Members and 1 Guest are viewing this topic. Read 4066 times.
feel a little silly asking, but i honestly don't know. other than eyeballing of course.
FWIW, I use a laser lever held flush against the inside wall of the speakers to aim them at my listening spot. However, I listen near-field (~8') in a constrained (i.e. small, oddly shaped) room, so YMMV. Good luck. Cordially,
My method is measure the distance from the front inside corner of the speaker to the wall behind, measure the distance from the outside rear corner of the speaker to the rear wall and figure the difference. Repeat for the other speaker. This does not tell me the angle but I can get the same toe in on each side, which is what I'm after.
I like measuring from the rear wall to a corner of the speaker, repeating the process with the other one. Another method would be to run a string from one speaker's outside corner to the other one. Then use a protractor and measure the angle between the speaker front and the string. At least you will have the speaker toe-in the same, as the back wall may be uneven.Wayner
Eh, I just "eyeball" it! I just aim the speakers, (repeat as necessary to find the ideal angle) then I put on a mono recording and move my head left to right till I find the exact center!
...other than eyeballing of course.
