0 Members and 1 Guest are viewing this topic. Read 5218 times.
On the Mini, is iTunes logged into your iTunes account? You must be signed in to retrieve album artwork from the database.Edit: Actually, I think you have to be logged in to also retrieve artist/album names, etc., which you are getting.Hmmmm..... Steve
Another aspect to this is what are the titles the OP is looking for? I don't use the artwork function, but do use the Track Names. Most of the time, I have to upload track information for classical titles, and obscure/fringe stuff. I wouldn't expect it to be any different on the artwork side...
However, it never seems to come back with the album artwork. I end up having to cut/paste the artwork into the files myself.So this is one computer where it always works right every time and one where it never does.
Just to confirm -- yes, I have no trouble at all retrieving track names, but artwork retrieval just doesn't seem to work at all. No real exceptions at this point.-dB
I know you're not getting artwork automatically when importing CDs. This probably isn't any different, but I was curious if you have also tried either of these two manual methods? 1. From the iTunes menu, Advanced > Get Album artwork OR 2. Select all songs. Click File > Get Info, then check the Artwork checkbox on the Info tab and click OK. Steve
Yes, I have tried both these methods. With the first one, it tries to get artwork for EVERYTHING, so I have not let it run its course. First, I have a number of hard-to-find titles, so I don't want it overwriting something I had to hunt down manually. Second, I was too impatient to let it do the whole thing (over 8k albums).
dB, so you're saying that it would download artwork with this method?
Using iDentify I go to my itunes file then just drag the files into iDentify that never got tagged in itunes.Works on every file that I have put into it.
but the first thing you need to discover and fix is whether your iTunes is getting any of the obvious iTunes-certified artwork. Go to the iTunes store and see if some of your artists are offered there; you'll at least know that your iTunes "get artwork" function should be getting those!
