0 Members and 1 Guest are viewing this topic. Read 7475 times.
Quality of the sound is my most important concern.
With DAC, since you coming from analog before I would recommend you try NOS (non oversampling) DAC first. Well, as long as you don't play high-res files of course.
Are you sure about that? Re-read your original post.Check this out when you have some time to kill : http://www.enjoythemusic.com/magazine/viewpoint/0601/audiohell.htm
Hey! If you ask me. I have to say that the first mistake is that you got rid of you analog. I do understand that with analog vinyl is take more time but than that is about quality vs quantity. Anyway, hope that you still kept all you vinyls. Back the the system. Looking at your system list. I do have one recommendation and that is get rid of the PS Audio DAC. I've heard PS Audio DAC before in one of the member of now gone NAYR Circle here and I have to say that it didn't sound right. It dose sound very precise and detailed but overall it sound very mechanical. And of course that member no longer using the PS Audio DAC now. With DAC, since you coming from analog before I would recommend you try NOS (non oversampling) DAC first. Well, as long as you don't play high-res files of course. I don't know about your speaker. But having a good tube amp is not a bad thing. Some people like to tube and some like SS. So, if possible audition them in your system first before making decision. Good luck.Take care,Buddy
I own the Rogue Cronus and it is the perfect match for my equipment and the sound I was looking for. A little back ground....I have many amps in my house. Both tube and SS and I was never satisfied with any of them. Then I purchased the Cronus, it has the perfect sound between tube and SS that I was looking for. Of course with any amp, it depends on the speakers and other equipment used..........
kingdeezie, could this all be related to the DAC? I've no experience with any of your gear BUT over the years I have noticed a lot of people mention the "sterility" of their PS Audio gear. Anyway, can you roll some other DAC into the system? Another thought would be to try a tube power amp in place of the Pass 250.5.The big question is do you have access to other gear on a par with your already high caliber equipment list that you can try some gear swapping? I won't drag cables into it.Are you looking for more tone? If that's the case then you can explore the possibilities of a vintage tube preamp (or a modern one based on a vintage circuit). MapleTree Audio Design have tone, so do most of the VAC preamps.However if it were me I'd start with the DAC, just my .02.Jake
I have noted the Tempest III. I was at one point looking at Rogue monoblocks. Do you use the Cronus?
I don't know if its the source
the amplifier
the speakers
or what, but something needs to change.
Its not so much tone as it is just a little bit smoother sound. Things are too..."jagged, hard, sharp.." at the moment.
Hello kingdeezie, Sorry to hear that you are no longer enjoying your system. I cannot tell you where the problem is coming from as I obviously only know one component in your system. I can tell you that with all the Purity One preamp out there, we have yet to receive any feedback such as what you mention here in this thread. The Purity One is designed to be clean, fast and articulate but never sterile. Especially the way your unit is built and capacitors used for output coupling. The Basis, in comparison, has a bit more warmth due to the circuit and 6SN7 tubes.By the way, how would you compare your current amp vs the amp you use to have when you purchased the pre. If you get a chance to come up to our place, you can audition the Basis Integrated Hybrid amp (which also has HT bypass, pre out and main in). If you cannot make it up anytime soon, I may be able to send one out for you to audition but it would not be till after February at the earliest before I could do so as I have a big gathering planned for the end of February. Another option as others have mentioned is to look into a tube amplifier which would really change things considerably. I am not familiar with your amp but I do have two other customer that run his amps (don't remember which models) and said they are a bit dry sounding. If you find an amp of your liking, I would have no problem installing HT bypass into your current Purity. Hope you find your way with your system soon. Bill Purity Audio Design
Good for you KD. Long time no talk.
As an update to this thread I have purchased a pair of Manley Neo Classic 250s off Audiogon...Should be good, hopefully.
