Choke replacement SE9
bwp
« on: 14 Jan 2011, 10:32 pm »
Anyone know of a direct replacement for the factory choke in the SE9?  I was popping fuses and the choke was the cause, cannot get a response from Yuths. My tech has a replacement for it but wanted to confirm with Norh, if no response he will just pop it in and give it a shot.
petrL
Re: Choke replacement SE9
« Reply #1 on: 19 Jan 2011, 08:48 am »
It's probably custom part. But the value isn't critical. Moreover it's an oportunity to use bigger one (more Henrys --> even less hum, although the stock SE-9 is already very quiet). The only constraint is a minimal cross-section of the wire to pass the current, but the tech is surely well aware of this.
