Bryston 3B question for Mr. tanner:
0 Members and 1 Guest are viewing this topic. Read 1193 times.
colhogan
« on: 14 Jan 2011, 10:36 am »
James:
 I have a single  Bryston 3B (About 20 years old,but working fine), powering a pair of Magnepan MMG's.Thes sound is good,but I'd like to get a bit more volume from the Maggies so I
  was wondering if I adding a second 3B of approximately the same vintage,and running them in mono. Would this harm either the amps or speakers in any way? :green:
Patrick
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston 3B question for Mr. tanner:
« Reply #1 on: 14 Jan 2011, 10:44 am »
Hi Patrick,
The Maggies are a more difficult load, due to low impedances, than a typical standard dynamic speaker so I would not recommend bridging a stereo amp into mono on them.  When you bridge a stereo amp it 'sees' 1/2 the impedance it does in stereo.
I would say go for a 4B and I think you would find the performance much better.
james
