Bipole or Dipole and the design
0 Members and 1 Guest are viewing this topic. Read 3762 times.
ttan98
« on: 13 Jan 2011, 06:04 am »
I like to design a dipole with 2 full range drivers(each is 4ohm) mounted back to back and wired them in series and out of phase. Both of the drivers are mounted on a sealed enclosure. I think that would make the setup a dipole instead of a bipole.
If I have only a single driver on a sealed enclosure the capacity is about 4litre to give me a -3dB of about 90Hz. If I increase to 2 drivers do I double the capacity or still remain at 4litre to give me the same bass roll off.
I would appreciate a response.
Duke
    • http://www.audiokinesis.com
Re: Bipole or Dipole and the design
« Reply #1 on: 13 Jan 2011, 06:56 am »
A dipole will roll off a lot higher than a monopole in general, and two woofers wired in a dipole configuration sharing the same internal airspace is something that I have no experience with.  So unfortunately I cannot advise you on an internal volume that will give you the same bass rolloff as a single driver in monopole configuration.
« Reply #2 on: 18 Jan 2011, 08:45 pm »
Why not provide separate enclosures for each driver?
And why not use separate binding posts so you can play with both dipole  and bipole configurations?
Duke
« Reply #3 on: 18 Jan 2011, 09:01 pm »
Maybe that's what ttan98 meant, and I misunderstood.   In that case, he'd probably want each woofer to have roughly the same internal volume as a single monopole woofer, but he'd still have dipole cancellation in the bass region working against him.  However in the bipole configuration, he'll have a net increase of bass energy relative to the rest of the spectrum because the output of the rear-facing driver will add in semi-random phase in the midrange and treble regions, but will add in-phase in the bass region.  You don't want to start out with a woofer/box combination that has an upper bass bump and then bipole it, because you'll probably end up with too much upper bass energy.
« Last Edit: 18 Jan 2011, 11:15 pm by Duke »
