Disc Repair Machines
Peter J
  • Hmmmm
« on: 12 Jan 2011, 08:00 pm »
Couldn't really find what seemed like the right circle to post in, so I'll do it here in hopes that those that have opinions will see and post.
I need a way to clean up scratches on discs. Used ones often need a little attention, but the price is really right sometimes...especially now with MP3s and music servers.
I've got a Disc Doctor that cranks, it actually works pretty well but if I've got to do several discs, it's a pain. I'd rather have something motorized. Before I go for the motorized version of Disc Dr., I thought I'd tap the collective wisdom here.
I have seen commercial machines, but thats probably extreme overkill
for my uses. Something shy of $100 is probably my range.
Favorites, condemnations or comments appreciated.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
Re: Disc Repair Machines
« Reply #1 on: 18 Jan 2011, 11:46 pm »
electricbear
« Reply #2 on: 19 Jan 2011, 12:51 am »
I bought a unit about 10 years ago from Bed, Bath and Beyond that was like a little walkman. I think I paid about $20 for it. It did a great job but only lasted about 4 years before the motors burned out.
tjohnusa
« Reply #3 on: 20 Jan 2011, 12:03 am »
Try using polishing compound available in any auto parts store with cotton balls. Polish disc with small amounts on the ball in circular motions and then rinse with water. If disc still won't load, or skips repeat the process. I have cleaned up some pretty bad discs with this for cheap. Of course if the scratches are quite deep they are probably done for. You cab also get grinding compound but this is much more abrasive and will require you to go over it with polishing compound for the final steps. Hope this helps....
rob-fi
« Reply #4 on: 21 Jan 2011, 05:03 pm »
I have used manual cd cleaners, and i think i found the one you mention (or similar)
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A0630588&cs=04&c=us&l=en&dgc=SS&cid=52102&lid=1342490
Its very cheap, but it does a nice job.
rollo
  • Rollo Audio Consulting -
« Reply #5 on: 21 Jan 2011, 05:58 pm »
  Agree 100% very affective and inexpensive to boot. Really look no further.
charles
Noseyears
  • SS-Audio
« Reply #6 on: 25 Jan 2011, 11:52 pm »
Nice idea above, but i think peter is looking for something motorized.
The one on amazon caught my attention.
