0 Members and 1 Guest are viewing this topic. Read 10493 times.
Have you tried just adjusting the overall balance of the left vs. right speaker and keeping the pots the same level. Make sure both posts start at the same spot. Often it seems the pot on one speaker isn't put in the same way as another so 12:00 on one speaker might be 1:00 on another speaker -and why I suggested markers on the back if pots 'must' be there.
How padded down are your neos now in both speaker? Is the Neos lower, higher, or 'perfectly matched' to the woofers? Can't say right? Though one speaker's set diff. from the other, both are setting the neos to lower effi. than the raw driver could be. That's at least a known fact to work with. IMO, for such a critical driver covering a HUGE bandwidth that's not too effi. in the first place.... I just don't see that as a plus? Imagine if the neo panel and your 6.5" woofers were the exact same effi. (and they might be? both should be I think ~86-88db) and you could then eliminate pots or sepp. resistors from the signal path again to a factual known improvement. You'd still need to pad down the super tweeter (whichever type you have), but it could be done w/ resistors at least.
Most designers, as mentioned previously, intentionally design their loudspeakers for optimally flat response. ...
See it's posts like your last one Brian that have kept me harping of the fuzzy or flat out fictional claims you make. I woulda thought you'd have figured that out by now. Instead of insulting me (which I promise you won't hurt my feeling or make me cry. hehe).... if you wanted to not look like a child or like you actually knew what you were talking about you'd just post specifically how I'm wrong. I've always said I'm willing to learn something if I'm wrong.
See it's posts like your last one Brian that have kept me harping of the fuzzy or flat out fictional claims you make.I woulda thought you'd have figured that out by now. Instead of insulting me (which I promise you won't hurt my feeling or make me cry. hehe).... if you wanted to not look like a child or like you actually knew what you were talking about you'd just post specifically how I'm wrong.
