Other Stuff
Archived Manufacturer Circles
Eighth Nerve
Installation help needed for Roompack
pugs
16 Mar 2004, 02:53 pm »
I received my roompack plus yesterday. I'm just wondering how tight the pieces should fit against the wall. Is it OK to have a little sag? Should I be using more than 4 pins for a seem to get it tight against the wall. Same thing for the corners and echos. Any other tips?'
pugs
One more thing........
16 Mar 2004, 02:56 pm »
One more thing. Should all the horizontal pieces that are at the edge of the wall and ceiling be at a 45 deg. angle?
8thnerve
Reply #2 on:
16 Mar 2004, 03:05 pm »
Yes, they should be at a 45 degree angle. And a little sag is okay, but strech them a bit for best results. There are always extra push pins, you can use a fifth one on the horizontal Seams in the center. That will reduce some sag as well.
Other Stuff
Eighth Nerve
