I need a Cheap and Cheerful head amp that will run on 12V
siava1018
So im going to order my dodd buffer this week and since its going to replace my receiver im going to loose a way to listen to my cans at night. Since the buffer and my dac are off the grid id like to keep my amps off too but im having a hard time finding something that runs on 12v.  DIY is ok. I have a pair of HD555's and a pair of brainwaves M3 iems and ill be geting a pair of high end high ohm cans in the spring.
TrungT
Re: I need a Cheap and Cheerful head amp that will run on 12V
« Reply #2 on: 5 Jan 2011, 03:48 am »
12V DIY
Class D
srb
« Reply #3 on: 5 Jan 2011, 04:07 am »
12V DIY
Class D
To drive headphones?
TrungT
« Reply #4 on: 6 Jan 2011, 10:11 pm »
No, wish it can.
I should read little more  :oops:
tomwhite
« Reply #5 on: 12 Jan 2011, 03:54 pm »
To the op.
Which high end phones are you planning to buy?
gary
« Reply #6 on: 12 Jan 2011, 04:12 pm »
I'm probably going to pick up an iBasso D6 when it comes out, it looks ideal to go between my macbook pro and my SM3 iem's. Unfortunately it's just coming out so there aren't very many reviews out there. If you don't need the DAC there are lots of reviews on their amps around the web.
gary
siava1018
« Reply #7 on: 14 Jan 2011, 04:44 am »
idk prob AKGs, i have other thing to take care of first.
