Pure Music!
0 Members and 1 Guest are viewing this topic. Read 14836 times.
Nels Ferre
Re: Pure Music!
« Reply #60 on: 22 Jan 2011, 04:15 pm »
Nels,
Thanks.  One more follow-up; could you explain "sounds better" between the Macbook and the Mini?
"Sounds better" was kind of vague--sorry.
First is a very noticeable reduction of the noise floor, adding to a sense of increased dynamics.
Clarity is noticeably improved.
Bass may be tighter, not so sure on this-
JDUBS
Re: Pure Music!
« Reply #61 on: 22 Jan 2011, 04:33 pm »
I bought 8GB Crucial branded memory for my 2010 Mac Mini for around $100 shipped from Newegg. Works like a charm. There are lots of other less expensive options but users are reporting very high defect rates with the less expensive memory.
How about this one for an '09 Mini?:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148276&cm_re=crucial_8gb_204-pin-_-20-148-276-_-Product
-Jim
jrebman
Re: Pure Music!
« Reply #62 on: 22 Jan 2011, 04:47 pm »
Jim,
I bought mine from OWC for about $100 and it comes with a lifetime guarantee, is CL-7 instead of 9 like most, and you can also send your old memory back for credit if you wish -- as long as it meets certain requirements.
I don't know what newegg offers, so this may all be moot, but wanted to let you know about this option.
-- Jim
jaywills
Re: Pure Music!
« Reply #63 on: 22 Jan 2011, 04:59 pm »
+1 for OWC (Other World Computing) (no affiliation).
Nels Ferre
JDUBS
Re: Pure Music!
« Reply #65 on: 22 Jan 2011, 05:46 pm »
Looks right to me.
Thank you, Nels.
-Jim
dburna
Re: Pure Music!
« Reply #66 on: 23 Jan 2011, 07:26 pm »
-Jim
So this is DEFINITELY the right memory for a 2009 Mac Mini?  Just want to double-check before I purchase same.  My (headless) Mini is sluggish on a number of tasks, so I thought this would speed it up a bit.  Any possible improvement in sound quality would be a bonus.
Thanks, -dB
Atlplasma
  • Just off the boat
Re: Pure Music!
« Reply #67 on: 23 Jan 2011, 07:35 pm »
Just an FYI on the install for your 2009 mini. You might want to check out the how-to video at otherworld computing before placing your order. Just make sure you're comfortable with the process since it's a little intimidating.
dburna
Re: Pure Music!
« Reply #68 on: 23 Jan 2011, 08:06 pm »
Thanks for the tip.  OWC video was easy to understand.  I feel totally comfortable working this memory upgrade.  Looking forward to getting a bit more speed.....soon!
-dB
JDUBS
Re: Pure Music!
« Reply #69 on: 23 Jan 2011, 08:12 pm »
Guys, is anyone interested in a separate thread involving using Pure Music, an 8-channel firewire DAC, and some plug-ins to create a fully active speaker system?
I have a DEQX but just bought an '09 Mac Mini and TC Konnekt 48 to replace it in a 3 (soon to be 4) way system.
I'll be learning as I go but it might be helpful to others if they are looking to do the same / similar thing.
-Jim
guest4954
  • Guest
Re: Pure Music!
« Reply #70 on: 24 Jan 2011, 07:49 am »
Would be nice to follow your experiences in a separate thread
Michiel
