0 Members and 1 Guest are viewing this topic. Read 10216 times.
Ted, my point is that if you give me a ripped redbook 16/44.1 file, and I upsample it to 24/96 (with no real gain in file quality or resolution), the reprocessed file will show 24/96 in the file properties, foobar and any other player's file info. Jamesg11, I will have to do a little research, but I believe mgalusha here on Audio Circle posted some frequency screenshots comparing files that were from 24/96 masters and files from upsampled 16/44.1 files. Steve
A secondary issue is whether the files are upsampled from original redbook or are true hirez.....is there a direct reason why we are asking this? Do they sound less than what folks were expecting, and therefore suspect a faux hirez upsampled example?
If it's the album I think was downloaded, there was no reference to the sampling rate, only the bit depth, so I was curious (and perhaps a little skeptical) about what was actually being sold. Steve
The files sound good to me, we were just curious about how high the high res was and if we could somehow figure it out from looking at something that would be displayed along with the file properties. Curiosity on my part.
Dumb Question... Can music files purchased online be burned to a CD and be played back on a CDP?
Although iTunes doesn't have columns for sample rate and bit depth, the Bit Rate column can be used to indicate it. For uncompressed WAV or AIFF files 1411 kbps = 16/44.11536 kbps = 16/482116 kbps = 24/44.12304 kbps = 24/484232 kbps = 24/88.24608 kbps = 24/96 Steve
Steve, why would you say iTunes doesn't have a "sample rate" column...it does, always has!
By the way, I just downloaded a song from Brian Eno. It's a 24/44.1k file. Sounds very good, too...Audacity won't show much cuz frequency response in a spectrogram isn't much higher than redbook, just 24 bit.
Ted, sorry to frustrate you! I know you must have a pretty good assortment of high res files (I don't have very many yet). Have you personally found that the biggest improvement is increasing the bit depth from 16-bit to 24-bit, and that the increase in sampling rate from 44.1KHz to 96KHz makes much less of a difference? Steve
Yes, if they are 16-bit/44.1KHz files (or down-converted) which is the limit of a CD Player.
