How 'Bout the Laser
0 Members and 1 Guest are viewing this topic. Read 2441 times.
  • Speakers....What Speakers ?
How 'Bout the Laser
« on: 14 Mar 2004, 11:16 pm »
I'm wondering...is there a big difference between the laser's in different CDP's or DVD players ?? Anyone got an answer for me ?? Is one better than the other ?? Thanks !! :)
Alex Peychev
    • http://www.aplhifi.com
How 'Bout the Laser
« Reply #1 on: 15 Mar 2004, 02:45 am »
There is a  difference in the Laser Pick up assemblies. Of course some are better, some worse but in general, it is a device that is pretty straight forward - Laser Diode, Prism/Lense and Optical receiver IC. The most important is probably how reliable the pick up is.
There were older pick up designs by Sony using FE, TE and RF amplifiers built in to the optical receiver IC. These were the best.
BenF
  • Guest
Sony Laser Pickups "These were the best."
« Reply #2 on: 15 Mar 2004, 05:42 pm »
Alex,
Which machines used these? How far back? Are they still made?
Thanks. Ben
Alex Peychev
How 'Bout the Laser
« Reply #3 on: 15 Mar 2004, 10:03 pm »
Hello Ben,
Sorry to say these are long gone, but you can still find them around used. Their reliablty is enormous, so no problem there.
Sony CDP-X303ES, CDP-X559ES, CDP-X707ES, CDP-X779ES.
With some PS mods and Precision clock these turn out to be the best CD transport money can buy.
Alex
BenF
  • Guest
Thanks Alex
« Reply #4 on: 16 Mar 2004, 01:22 am »
I appreciate you sharing your knowledge.
Ben
