New Member
Jeopomytiethy
New Member
« on: 24 Dec 2010, 01:54 am »
Thanks for the approval! I look forward to learning from everyone here, and hope to contribute as much as I can.
akc
Re: New Member
« Reply #1 on: 3 Feb 2011, 06:55 pm »
I'm new here too, just got my WTA, it was a demo model with ordinary feet and a square hole for the spindle ( does it matter?) I had mine fitted with the WT arm lift. This is well engineered and at a stroke removed my only concerns regarding the deck. Sound is fabulous.
threadkiller
Re: New Member
« Reply #2 on: 5 Feb 2011, 04:48 pm »
Welcome aboard!
no, your feet and hole don't matter!  lol....
with the newer feet it allows you in most cases to not use the isolation board...even with the older footies, for some folks no further isolation was needed.  I picked up quite a howl and had to use the isolation board.
Enjoy!
Chas
