0 Members and 1 Guest are viewing this topic. Read 7608 times.
Are there bypass caps on the low pass filter as well? I ordered some Platinums and am getting four. If there is a bypass on the lowpass wouldn't I need six?
Ron,I'm getting ready to build my first N3S. Looking at the placement of the 2 XO boards, it looks like they rest on Brace A, blocking the 3" holes. Is it OK to block them?Bryant
Thanks Danny. Also, do you install No Rez all the way to the edge of the front baffle, or a couple of inches back (like as shown in the TL version)?
Just like in the drawing.
Hi, forgive me to bring up this old thread. I have the same question on the N3 TL box. The plan only shows the length of No Rez on the top side. And I measure by the scale of the plan it's about 7.7", eg 2.3" from the rear side of the front baffle. Is it correct?
Also there is no drawings to show the length of all side mounted No Rez. Are they the same as the top one?
1.5" - 2" is room enough.You got it. The side pieces are set back the same distance from the baffle.Ruben
