Help! Mildew/Mold on Omega speaker drivers
0 Members and 1 Guest are viewing this topic. Read 2034 times.
Beano
« on: 22 Dec 2010, 06:27 pm »
Hi all,
I live in the tropics where humidity is very high and unfortunately despite frequent use of a dehumidifier in my listening room, I noticed mildew/mold spots on my Omega 6 drivers :(.  Appreciate any advice whether I should attempt to clean it and if so what cleaning agent can I use on the hemp drivers without damaging them....
HY
Louis O
Re: Help! Mildew/Mold on Omega speaker drivers
« Reply #1 on: 24 Dec 2010, 07:49 pm »
Hi HY,
The humidity won't hurt the drivers. As to the spots, I can only think of Bleach, but this will take the color right out of them.
I might try on a set old old drivers.
Louis
