Air gap
drummermitchell
Air gap
« on: 21 Dec 2010, 12:23 am »
Just wondering what happens to the sound if you are using say GIK 242's behind your main speakers
and you install,say 3 door stops(for each 242) to keep the panels off the wall .
what is that suppose to do to the sound.
Has anyone done this,thanks.
bunnyma357
Re: Air gap
« Reply #1 on: 21 Dec 2010, 12:44 am »
My guess is that it would make them less effective, as the GIK's have an air gap built in. It would probably work well for panels with no gap.
I guess the best way to find out is try it. Let us know the results if you do give it a try.
Jim C
Glenn Kuras
Re: Air gap
« Reply #2 on: 21 Dec 2010, 04:36 pm »
Hard to say, but it would absorb more low end. As said before we do build the gap in them so I would recommend sticking with that.
