question on impedance
0 Members and 1 Guest are viewing this topic. Read 1446 times.
David C
  • Don't try and lay no boogie woogie on the king
« on: 20 Dec 2010, 05:12 pm »
I have read that the load or amp impedance needs to be at least 10x that of the source. I have Nuforce P9 pre input 10K ohms and output 100 ohms with Nuforce 9V3Ses amps input 22K. I have a relatively cheap Sony CD player that use the optical out to a mini max EE DAC. in the tube output Bill from Morningside Audio said the out put impedance of the DAC is 7.5K (depending on vol control settings) and SS out is 200 ohms. My question is given the tube output of the EE DAC  should I look to invest in one of the impedance "matching" or buffer for a lack of better words boxes that are sold. My current set up sound fine to me?????????
Speedskater
  • Kevin
Re: question on impedance
« Reply #1 on: 20 Dec 2010, 06:04 pm »
Do you connect the tube output (7.5K) into the P9 (10K) or the 9V3Ses (22K) ?
It's not the best situation but:
In either case, if you use short interconnects you should be OK.
David C
« Reply #2 on: 20 Dec 2010, 06:28 pm »
CD to EE DAC to P9 then to amps
« Last Edit: 21 Dec 2010, 05:03 pm by David C »
