0 Members and 1 Guest are viewing this topic. Read 71811 times.
I am in a relatively unique position with the NFB-3 in that I have both the 24/96k (DIR9001) and 24/192k (WM8805) modules. I don't feel a need to make a lengthy review stating every aspect of my setup, my hopes and dreams and all that so I'll keep it simple. On my setup, listening to James Taylor in FLAC -> NFB-3 -> C-2 -> MS-pro the difference between these two modules is very apparent. The WM8005 is very mellow, missing many details and rounding out the sound. DIR9001 is a completely different beast, outclassing the WM8005 in every way (except 192k handling). The details come right through, extremely transparent, hits hard and fast, no mentionable issues at all. You can get the DIR9001 module from Audio-gd for only $22.50 and for those with the WM8005, this is a very worthwhile upgrade!
ES9018 Sabre NFB11 will be available Mar. 1. Looks like there will be a 30% discount off the DI (Digital Interface) usb/spdif converter to go along with it since it does not come w/usb. Great deal since from what I've read the DI sounds almost (I said almost, jkeny) as good as the jkeny modified Hiface.http://audio-gd.com/En%20audio-gd.htm
Would like to hear your listening observations when you have time with direct mode.
Sure, will do. In this whole thread, am I the only person that actually bought an NFB-12? I can understand that actually, for a dedicated DAC the NFB-3 is probably more attractive. This one is for "portable" use as well as in the study - the DAC in my USB measurement gizmo is horrible.Initial impressions: for $200, the build quality is incredible. It has a stack of regulators in it. Haven't got a handle on the sound yet but I'll let it play for a while and settle down.
Any good reports yet on this unit??
