Re: DIY Dodd Buffer group buy - $300each
Atlplasma
  • Just off the boat
« Reply #80 on: 20 Mar 2011, 11:05 pm »
Strange. I know the wire colors have changed, but it seems my connections are different.
Brown
Black
White
Black
Brown
White
If I check the module photo on Gary's site, the twisted wires are as follows:
Black
White
Brown
Since my unit works, maybe it's more important that the other end of the wire is connected correctly.
TrungT
« Reply #81 on: 20 Mar 2011, 11:21 pm »
I think the black wire is important (Ground)
2 other wires does not matter. (your buffer singing with wrong color)  :thumb:
Just make sure it go to the right place.  :wink:
Atlplasma
  • Just off the boat
« Reply #82 on: 21 Mar 2011, 06:52 pm »
I put my meter on the untwisted wires. In the current configuration, there is 6 volts at the white wire and 13 volts at the brown.
Atlplasma
  • Just off the boat
« Reply #83 on: 21 Mar 2011, 09:59 pm »
Brown
Black
White
Black
Brown
White
Black
White
Brown
I checked my wires again, and they are consistent with the module picture on Gary's site. So all is well.
2wo
« Reply #84 on: 21 Mar 2011, 10:07 pm »
Thanks for checking for me. BTW it appears the module will work with the bottom brown & white wires ether way...John
