0 Members and 1 Guest are viewing this topic. Read 446479 times.
Here's a temporary diversion back to the AT95e.A German gent has come up with a tripod cantilever mod. "It puts Ella in the room."It helps if you read German but Google Translate makes it understandable.http://de.schiller-phono.de/produkte
Neo, good work with the JVC. The comparo with the AT20 is particularly apt since many of us have or have had a variation of it. Helps assign a rank. By all means, if you can, try it on a different arm. If it still doesn't out play the 20, well... I think your instincts about the German cantilever guy (he calls it 'Space Needle'. Wonder if he's been to Seattle?) are correct. The unstated assumption seems to be the added ETM is offset by the stiffer cantilever. Wasn't there a Shure paper that said alu cantilevers whip like an unattended garden hose? If so, that would explain other companies use of diamond and ruby as materials. It's interesting users of the exotics and the tripod cantilever both cite tremendous "clarity" as the main benefit.
