0 Members and 1 Guest are viewing this topic. Read 446854 times.
Come to think of it, the strain gauge is the ONLY type of cartridge where development can in fact continue unimpeded....Standard magnetics have reached a dead end, and stepped back from their peak in the mid/late 80's. (exceptions: Dynavector Karat, Decca London ?)At some point I need to fix up my SG phono stage (which I believe to be the cause of a channel imbalance in my Panasonic SG) - I do recall it sounding quite stunning - but I had only just got it going and listened to one or two records when the channel imbalance appeared - I have been hoping since that it is the phono stage - but it has been in storage waiting for me to get a "round tuit" since...I have a feeling that although the SS SG has had further development since the panasonic effort (which SS was one of the few to service!) - the key to its achievement is in the phono stage that apparently does some proprietary EQ.... no details have been forthcoming in any of the reviews, nor have I seen any proper measurements of its performance ... which would be of great interest!As a mad keen electrostatic speaker fan since the mid 80's - the Strain Gauge cartridges seem right down my alley.bye for nowDavid(currently in the process of getting toddler friendly 'stats' operational .... ie: a pair of vintage Stax headphones)
The 1986 review shows that there is a slight (1.5db) trough starting at around 3kHz and ending at around 20kHz - probably the eddy current losses - starting to be offset right at the top end by the gentle rise to the resonance. (this was for an EPC205cmk4)(alternative theory for the trough is cantilever flex.... but Ortofon blurbs on the "super" OM seems to indicate that this is where Eddy current would become visible, and switching a stantering D7500 from a HO XSP3003 body to a LO XLZ body shows a marked reduction in the trough - which seems to indicate magnetic effects are the culprit)
P.S. the Ortofon MC200 which was considered a benchmark at the time, has a tip mass of 0.5mg (spec) - even though it has a boron cantilever ... making it heavier than the then current OM40 - the MM equivalent from the Ortofon range.... (Res F 20.9kHz)
Just quoting the etm from the mc200 spec sheet.... And translating it into an estimated res f...I have yet to measure one...
