Five of the M/C's I bought are 1) Ortofon MC 2000, 2) Klipsch MCZ 10 R, 3) Shinon Red Boron Improved, 4) Krell KC 100 (Miyabi Standard), 5) Denon DL 305
Hi Neo,My main phono stage is the BAT VK-10SE with the 6 pac option. I do have the manual and I do have the parallel resistance kit from db but I have not used it. I have a couple of cartridges that ask for 30 ohm loads, so I though I would try this db kit and load them at 30 instead of my minumum setting of 100 per the BAT. Knowing that this kit also has 2 empty plugs, I thought I would also try the 32K load that is recommended for the Grado Signiture 8M. Like I said, I have not tried this resistance kit. I decided I want to understand first just what was going on with these various settings. If I was to solder a 32K ohm resistor in the empty plug from db, and inserted it in line with my phono cables at the input location on the BAT VK-10, I would assume that I have loaded the installed cartridge at 32K. With this calculation formula, I do not know if this is true or not. In the manual, this is what is stated. **********Cartridge loading switchesResistance:The 47K load resistor is permanently connected to the cartridge input. If a different loading value is desired, it can be obtained by switching in additional resistors, installed on the VK-10 PC board. This is accomplished by using the two DIP switches, (S101) and (S202), that allow multiple choices for resistive and capacitive cartridge loading. Four positions are reserved for the choice of resistance and four for capacitance. Out of each group of four, one position is loaded with female pins and allows the user to install any desired value component (this position is marked "USER"). Gold plated solderable pins are supplied with the VK-10 accessory kit, that should be attached to either resistor or capacitors supplied by the user.The following resistors can be added in parallel with the 47K load. Switch position Resistor Value 1 100 Ohm 2 1K 3 10K 4 User-DefinedAny parallel combination of the these values is also allowable.Capacitance:Various values of capacitance can be connected in parallel to the input via switches (S101 and S102).With these switches in the OFF position, there is no capacitive loading to the cartridge.The capacitance choices include: Switch Capacitor Value 5 100pF 6 470pF 7 1000pF 8 User-DefinedAny possible combination of these values is also allowable.**********Neo, the above is word for word out of my manual. The switches 1 thru 8 are dip switches. Thanks for helping me tacklethis mysterious 'Voodoo'! (grin)Regards,Don
Although there is "springiness" to the cantilever it is unrelated to the low frequency resonance, and is notable only in the midrange losses caused by its flexing.By design it is intended to be as rigid as possible (no springiness) - and what flex there is to the cantilever is an imperfection/compromise caused by the realities of the limitations of available materials.On AT styli, all the "springiness" at low frequencies (compliance related) is therefore completely down to the rubber (or perhaps more appropriately elastomer) "doughnut".What is interesting is the discussion with regards to whether the screw is designed as a compression adjustment (and therefore a means of tweaking compliance) -or whether it is simply intended to keep the doughnut in place... The reason the screw is there might be just to allow adjustment of the cantilever angle through rotation, something that may not be relevant to lower end styli, where it is not even fitted.interestingbye for nowDavid
Hi Don,I will take a look to see whether it has a compliance screw.The needle holder on these is not plastic but a solid chunk of metal, which screws into the body - so there is no question about a positive mating with the body!I have a couple of these bodies with broken styli (intended for a retip at some point) - I will remove the stylus (stub) and look for a compliance screw....Need to find them in my storage first...bye for nowDavid
