Thanks GB,I ordered a smaller one. The table is 8 watt and that one is 500 watt. Just saw another vintage goodie:http://www.canuckaudiomart.com/details/649235290-empire-top-model-4000-diii-cartridge/$290 Canadian is $219 US. 3mV30cu.75 - 1.25gI'd get it myself but I'm a little backed up. That would be nice on my Sonus arm. neo
Neo,You're part enabler and part private shopper! AC
Hi Neo,I've used the following cartridges: Grace 9E, Monster Cable Alpha 2, Monster Cable Sigma 1000, Fidelity Research FR1 Mk3 original and a Soundsmith FR1, Accuphase AC1 and an AC1 retipped by Soundsmith, Denon DL107, Denon 103 original and with UWE wood body, Empire 4000D mk3, Koetsu Black with vdh tip, AKG P7, Nagaoka MP50. My favourite of the lot is the Empire 4000. It has all the detail of the moving coils carts with none of their agressiveness. Im looking forward to trying the Victor Z1.Regards,Pat
GB,I think your arm is on the low side of medium (10g?), but I'm not positive. I think it will work. I'm not sure about replacement styli.My experience is limited here and I don't want to throw you a curve. Are you a member of Karma? They have a giant Empire thread:http://www.audiokarma.org/forums/index.php?threads/anyone-else-running-vintage-empire-carts.468129/You could check with them. Somebody could probably comment about the arm.neo
GB,If you can load the M97 at 62K/250pF it improves a whole lot. Jico makes an SAS for it too, but I can't say I've heard it. They say with it, it's back to 47K and at a whole other level.The Z1 w/E stylus sounds sweet and natural. Maybe with a bit extra bass but basically flat. With the SAS stylus it will go up against just about any MM ever made, although you might have a preference for a different sound. This is fast, detailed and dynamic as hell. The AQ 8 is straight low/med mass arm? Should be great match. With SAS I track at 1.4g. 1.75 W/JVC stylus. I see the bid is up to $10.50 - don't bid too much if you go for it. They still show up from time to time, but mostly in Japan. These were not US models.http://www.hifishark.com/search?q=Victor+z1+cartridgeneo
I know this stuff is confusing and I didn't explain much. If you have questions don't hesitate to ask. If you don't understand parallel resistance and capacitance, all this must seem like voodoo.
I think you should get the RCM first and get that out of the way.
The other is capacitance - that's the total value of preamp + cables + internal arm wire = capacitance load. In this case (M97) you want to maintain at least 250pF, but not much more. Depending, your wire/cables might be 125 - 150pF. Combine that with 100pF on your preamp and you should be close. Only thing is you cable capacitance is unknown.
The capacitance of my RCA cable to the amplifier is roughly 21 picofarads per 2 ft, which since I have 3ft makes 31.5pF. Does the output to the amplifier even count? I wouldn't think so. The Audioquest tonearm is connected by an unknown SME tonearm cable that connects to the phono stage in. Any idea of how to identify it, or is that not really necessary?
