0 Members and 1 Guest are viewing this topic. Read 35917 times.
I was just describing that the PC is busted - no s/w can be loaded onto it, either XP or otherwise.As for the GUI, I am actually wanting a GUI ON the PC where the Vortexbox s/w lives - I have a full size monitor, and wireless keyboard and mouse, so it is great to pick songs directly on that PC, rather than introduce another into the environment.In fact, I have bought a used iTouch that can also access the GUI you are referring to, via the IP address with a browser - but only once I figure out what PC to next use for this application, my existing one died - must be motherboard, cause I swapped HD, but it won't work.
It would be cool this time around to pick one up with SATA drive, as I have a couple of those HD lying around, including a 500G that would hold most of my tunes. Once VB is installed, can you load music onto the drive over your home network, or some other way, or do you have to rip music to get it on your server?
Once I pick up a suitable SATA friendly PC, I will toss my usb 1TB drive directly into it. Then load up the s/w, and then use my backup drive to load it all on.
This thread go me started thinking, which is probably a really bad thing!!!I put together a list of stuff from Newegg that will run me $250ish shipped, basically a small barebones unit adding a 1TB Hard drive, a DVD burner and some memory. So before I pull the trigger I wanted to ask you guys a couple questions: 1) So I put it all together, insert a disk in the drive with the latest Vortexbox iso (got it already) and boot it up? Thats it? 2) I realize I'll need a keyboard and monitor for setup and have some old ones here, is it that easy??Any tips as this will be my first build of any kind as far as PC's go, I'm not totally clueless just lacking a bit of confidence in doing this. I figure worst case scenario is I can add a video card with HDMI port and have a HTPC if this idea blows up. Thanks!! Ed
