Subwoofers
0 Members and 1 Guest are viewing this topic. Read 4614 times.
yoaudio
Re: Subwoofers
« Reply #20 on: 7 Dec 2010, 12:21 am »
Is there any sonic or power differences between using a single RCA vs. using a Y Splitter?
I heard on some models of sub woofer amps if you use a y- splitter you would get a 3dB gain and if you just used 1 channel, you would just turn it up a little more. I didn't know if that was true with the servo amp.
