0 Members and 2 Guests are viewing this topic. Read 13156 times.
Has anyone called to see how much they actually cost?
Have you ever tried throwing a soft thick blanket over the TV during critical listening sessions?
You will definately hear a difference. That is what I do. On the top shelf of the rack to the right of the TV is my blanket. Usually if it's not a music DVD, the blanket is over the TV. My speakers are over 2 feet in front of the TV.
Boy, you sure can hear it! I have a 42" in between my speakers and I have a red blanket also for the tube.
I think the only one to stay away from is an electric blanket as it could introduce a ground loop into your system
I guess if I really wanted to get fancy, I could mount the TV on the wall and put up retractable curtains to cover the TV, just like a old fashion movie theater.
Do red blankets affect the sound differently than other colored blankets? What about a wet blanket? I'm sure there's someone that will argue this point!Sorry, couldn't resist. . .
Dang.....there goes that idea......thought it might sound warmer! Sorry...couldn't resist.
That sounds a little extreme, but in my opinion it would be a genius move. Seriously, that large glass surface between the speakers can certainly effect the sound. I am in the same situation as you, and I sometimes lean two panels in front of the TV while listening to music; the difference is obvious to my ears, but it looks so silly and is totally un-practical (is that a word?). Now the curtain idea... Oh, and definitely mount the TV; it gave me a little more image depth, but YMMV.LMAO! Hilarious!
The speaker positioning and covering reflective screen in between the speakers are very important. I would also suggest that comb filtering from the back wall is messing up your stage depth. I have about 10 ft behind my listening position and putting up a big diffuser on the back wall made a huge difference in imaging and establishing stage depth. I would not do without it.
Thanks for the suggestion. The situation behind my listening area is a little different. You can see the layout on this link:http://www.floorplanner.com/projects/20186902-living-room/ss4souThe cathedral ceiling height starts at 9ft at the wall behind the L&R speakers and slopes up to 19ft at the wall behind the listening position. The stairs behind the listining area lead up to a landing that's open to the living room and the hall behind the listening position leads to the den.As you can see the area behind the listening position (on couch) is a bit irregular.Any tips are appreciated. Of course the ultimate solution would be to have a dedicated room for this instead of using the living room, but that will have to stay a dream.
Irregular is good. Maybe something in the corner or on the door. You might want to loose that table tho.Most of us don't have a completely dedicated room. You eliminate as much as possible and sit back and enjoy.Did you order HT2-TL's?
Nice room you've got there!
Correct me if I am wrong, but didn't you mention the paladium window had thick curtains covering it? If not, definitely get some of those floor standing 2x4 acoustic panels. Glass = bad for sound.
Looking at that picture, if it were me I'd mount the plasma, lose the glass coffee table and move the couch back/speakers further from the wall. If the latter is not possible, I'd treat the wall behind the speakers, probably with at least two 2x4' 4" thick acoustic panels from Gik or Real Traps. Heck, I'd probably do that anyway Check these out:Wall behind speakers: http://www.gikacoustics.com/gik_artpanel.htmlLeft wall with window(s): http://www.gikacoustics.com/gik_242.html
I recently hung my PRO-151 on the wall. Sanus makes a great mount for it.
