**SALE PENDING**Cullen Circuits Filtered AC Outlet
0 Members and 1 Guest are viewing this topic. Read 1991 times.
Big Red Machine
« on: 27 Nov 2010, 02:45 pm »
**SALE PENDING**I only bought this to see how it was made.  Never installed.  They go for $70 new.
$55 shipped CONUS.
"The Receptacle filter consists of a 20 amp EMI shielded filter that has been wired to the Hubbell outlet (8300 series) with 14 awg 99.9% OFC copper wire. These not only will replace your cheap mass produced wall outlets but will give you a great outlet that filters the incoming AC. They will not drop the line voltage at all. Why spend all sorts of money on Power Conditioners when you can just replace a single outlet and have all of your components with filtered AC. Installation is easy these will fit into a single gang box and all you have to do is hook up the ground, line, and neutral with the wire nuts that are provided. These outlets are Spec/Hospital Grade, Made in the USA and will accept 15 or 20 amp Plugs. "
« Last Edit: 28 Nov 2010, 09:08 pm by Big Red Machine »
