active x-over for linn isobarik
0 Members and 1 Guest are viewing this topic. Read 8530 times.
hakan
« on: 10 Mar 2004, 12:43 pm »
Hi!
New member here, and I have a probem. My naim naxo filter filter is not working, so I am hunting for a new one.
Is David's 3-way kit working on Isobariks? Seems like it's a true bargain. As I understan it's got the PS included, but is there an option to go further in terms of making a super PS, like the snaxo-supercap combination.
Has anyone any ideas?
cheers
HÃ¥kan
davidw
    • http://www.wnaudio.com
« Reply #1 on: 9 Jun 2004, 02:09 pm »
The White Noise xovers can be used for sub bass units and in conjunction with almost any two or three way loudspeaker system. Ideally you need to know the crossover frequencies of your loudspeaker system - but you can always use trial and error if necessary. The pcb level kits and modules ( assembled and tested kits ) don't include a power supply - you need a cascode or other+/-15V power supply as well. The cased kits do include a power supply as well as absolutely everything else you need to make a crossover unit.
