0 Members and 1 Guest are viewing this topic. Read 9807 times.
I am also puzzled by how did a $6k turntable got on the under $2k turntable thread . Maybe poor math may have something to do with it.
It's called humor. Something I'm sure you're not familiar with.
Build a well sorted Lenco and you can leave that $6,000 Vpi to collect dust. You'll come in under $2000 including tonearm and cartridge and you'll have $500 to spend on your phono pre. The Jasmine phono pre mentioned earlier really is a phenomenal performer, and not just for the money.A rough breakdown of costs:Jasmine Phono - $525Lenco - $300/$400Jelco 12" arm & cable - $700Denon dl103/103r - $150/$250BB Plywood for plinth - $75/$150Here's a link to someone's first Lenco build, a pretty bog standard one by the way...look at what he's comparing it to. http://www.lencoheaven.net/forum/index.php?topic=4135.msg65709#msg65709
Your comparing a 40 year old turntable that will be purchased used and that requires DIY tools and skills to build....versus brand new and thru a dealer network with a warranty, etc. Quite a different set of circumstances.You buy any car (save a Mini maybe) off any car lot in the US today and it's value drops by 20% nearly instantly. So, there is an inherent cost of buying 'new' that everyone, at least conceptually, understands.I have no favorites to choose among either TT - may be the best table be the best table - but, you simply cannot compare the two in cost, but only in sound quality. What if the LENCO bought is old and needs re-building? I'm an inveterate tweeker, but I wouldn't know how to set the thing back to original operating stateThen, there is the subject of box building...I don't do it nor do many others in the hobby. So, I'd have to buy some $1000 plinth aftermarket...which ratchets up the cost of the LENCO appreciably. Again, you may well be right that a LENCO will somehow stomp a VPI Classic 3 for a lot less....but it's a bit of a mismatch to compare costs involved. Sound quality of and by itself - that's understandable.So, to the OP, unless you are an experienced in building a turntable...this is NOT a project for you. John
Vinyl cleaning system is a future purchase.
Spoke with a dealer; he has a demo Nottingham Spacedeck Jr.He recommended some other cartridge or a Grado; he said to use the ZPhono for now (or he has a killer demo phono pre-amp).Heavily considering on getting it; unsure about the cartridge.
