Poll
Are you interested in a USB DAC with wireless input?
Yes, I am interested in a wireless USB DAC.
16 (72.7%)
No, I am not interested in a wireless USB DAC.
6 (27.3%)
Total Members Voted: 22
AirDAC
« on: 21 Nov 2010, 09:03 pm »
Hi, I am new on the forum.
I would like to poll if you are interested in a USB DAC with wireless input.
The wireless DAC system compromises 2 units:
1. Transmitter
- USB input
- 24/96 support
- volume control
- headphone output
- wireless output
- battery powered (+/- 50 hours runtime / 500+ times rechargable)
- small 'tabletop' footprint (16 cm x 12 cm x 6 cm)
2. Receiver/DAC
- wireless input
- quality DAC (24 bit resistor ladder)
- fixed and variable outputs
- linear AC power supply
- small 'tabletop' footprint (16 cm x 12 cm x 8 cm)
The wireless technology promises the following:
- guaranteed free from RF interference
- plug & play, no network settings etc.
- 24/96 support
- SNR > 120dB
- true channel separation, 0dB crosstalk
- no latency (< 0.2ms)
- reach about 35 feet (indoor, single room)
Functionality
The wireless DAC system is useful for you, if you want to use a Laptop (or other USB audio device) as source component for your music library and control it at your listening position.
I think this might be an interesting product for (computer) audiophiles and checking out if I am right or wrong.
Your suggestions and/or comments are truly appreciated.
Cheers!
Arend
System layout:
« Last Edit: 23 Nov 2010, 03:55 pm by AirDAC »
jtwrace
    • TIPP YouTube Channel
Re: USB DAC with wireless input
« Reply #1 on: 23 Nov 2010, 01:15 pm »
Welcome to A.C.!!!
I voted "yes".
Is this something that is in early design stages or close to production?  What else can you say about it?
AirDAC
« Reply #2 on: 23 Nov 2010, 01:26 pm »
Hi jtwrace,
We do have a functional prototype, the poll is to find out if there would be a reasonable demand for this solution/product. And if this is the case, does the feature set fulfill most requirements, thus any comment/suggestion is appreciated.
AirDAC
« Reply #3 on: 23 Nov 2010, 01:36 pm »
We are also considering to offer a, software based (running on your laptop), digital room correction system with it.
jtwrace
« Reply #4 on: 23 Nov 2010, 02:40 pm »
Hi jtwrace,
What chip will you be using?  Async?
bpape
    • Sensible Sound Solutions
« Reply #5 on: 23 Nov 2010, 02:50 pm »
Volume control type?
Any chance of a D/D version so that other DAC's could be used if desired?
Bryan
jtwrace
« Reply #6 on: 23 Nov 2010, 03:17 pm »
Bryan
Great idea!
AirDAC
« Reply #7 on: 23 Nov 2010, 03:21 pm »
At the moment a Tenor IC, not async, btw I am not the electronics designer but the initiator. I am aware that async is 'hot' at the moment but as I have learned there are different ways to eliminate jitter as far as possible.
AirDAC
« Reply #8 on: 23 Nov 2010, 03:27 pm »
Bryan
Hi Bryan, yes we are considering to offer digital outputs on the version with DAC (thus the one described above).
We are also thinking of offering a 'wireless link only' version, thus without DAC but only with digital outputs like toslink, coax, aes/ebu and perhaps i2s.
The latter could be interesting for those who already have a good DAC with remote controlled volume.
jtwrace
« Reply #9 on: 23 Nov 2010, 03:30 pm »
I think this would be a HUGE item...
bpape
« Reply #10 on: 23 Nov 2010, 03:42 pm »
Agreed.  For something like a laptop or even an SB Touch, that would be something that would be interesting and avoid having to stretch wires across a room (which normally doesn't have high WAF)  :scratch:
You mentioned 'no latency' but I think (could be alone on this) that there would be some sort of buffering in the receiving unit.
Bryan
AirDAC
« Reply #11 on: 23 Nov 2010, 03:49 pm »
Bryan
We also thought about a dedicated SB Touch transmitter, compromising SPDIF input and regulated 5V, battery powered DC output on the transmitter side. In this case you can use the SB touchscreen at you listening position. I think this might be an interesting offer as well but we probably start with the USB version as this market is larger.
Latency is less than 0.2ms which is extremely low compared to RF solutions (typically between 7ms and > 30ms)
chadh
« Reply #12 on: 23 Nov 2010, 03:58 pm »
Welcome to AC, and thanks for the interesting post.
I'll apologize right up front for not being unequivocally enthusiastic about the product - but maybe some answers to my questions will help prove what a boon the Air DAC could be.
First - we know that "wireless" devices already exist.  Something like the slim devices/logitech offerings can operate wirelessly, and do so with a couple of advantages over your product.  By taking a wireless signal from the computer directly, they don't need to deal with the extra transmitter component, nor to deal with USB conversion prior to transmitting the data.  It seems that this new product complicates the transmission process more than solutions that already exist.
Despite all of this, almost all the people I know who use this kind of solution actually choose to use it via a wired ethernet connection.  This seems to be because the wireless receiver inside the device adds some noise to the system.
What does all of this mean?  Audiophiles around here seem to have shown that the wired/wireless issue is of far less importance to them than sound quality.  Especially as you can control PCs remotely with handheld devices or laptops or whatever, separating the PC controlling the music from the system seems to be becoming a less and less vital issue.  The thing that will make or break your product in the audiophile market (well, at least the Audio Circle market) is its ability to deliver superior sound quality.  So, I think it would be best to address the question of why your transmission system:
PC -> USB connection -> transmitter -> some kind of wireless transmission -> Air DAC
would produce better audio quality than
PC -> USB connection -> typical USB DAC
or
PC -> USB connection -> USB-SPDIF converter -> typical SPDIF DAC
or
PC -> WI-FI transmission -> squeezebox
or
PC -> ethernet connection -> squeezebox
Many thanks.
Chad
wilsynet
« Reply #13 on: 23 Nov 2010, 04:02 pm »
Why wouldn't I just use a Squeezebox?
AirDAC
« Reply #14 on: 23 Nov 2010, 04:56 pm »
Thank you Chad.
No problem, this is the reason I started the topic.
Some prefer to use a laptop as source because of more flexibility (interface/software/usability), with AirDAC they don't need to run a long USB cable. As far as I know the transmission is not more complicated in case of USB audio, conversion is only at a different point in the chain. The USB signal is converted to i2s before being wirelessly transmitted and feeded without conversion to the DAC (USB -> I2S -> DAC).
That is because of RF technology, 'our' technology differs from RF and has a potential 140dB SNR and discrete channels. Unfortunately I can not go into details because I want to respect the NDA with the technology provider. But it's a serious alternative for a wired connection and offers zero noise.
WAF and convenience are important to some degree otherwise PC based audio solutions like music streamers and servers would not be on the market. The AirDAC solution does not compromise on SQ and serves both WAF and convenience arguments.
I agree but using the native interface on your listening position is, in my opinion, more convenient than a smartphone like device.
That will depend on the USB DAC
or
Same here
or
Both our transmission and DAC are better than that of the squeezebox.
or
Our DAC is better. Regarding the connection, there will be no difference in SQ comparative to the ethernet connection. Ethernet supports bit/sample rates larger than 24/96 but the squeezebox does not.
Many thanks.
Chad
Thank you for your serious comments, appreciated.
« Last Edit: 23 Nov 2010, 06:32 pm by AirDAC »
jtwrace
« Reply #15 on: 23 Nov 2010, 05:25 pm »
AirDac
I really look forward to hearing more about the products.   :thumb:
I'll take one!   :)
bpape
« Reply #16 on: 23 Nov 2010, 05:42 pm »
Chad.
The biggest bennie for me in the touch type version would be not having to wire from the Touch to the system.
Right now, yes, the Touch will connect wirelessly to the server - but not to your audio system.  I would still need to run approx 25' SPDIF or analog interconnects from my seating to my preamp.  With this solution, I no longer have to do that.  All I need is power. Wireless from server to Touch, wireless from Touch to preamp or DAC which is across the room from the Touch.
Bryan
bfr1992t
« Reply #17 on: 23 Nov 2010, 08:01 pm »
I'm interested in hearing more. Remote volume control would be killer, esp if it's RF and not in the 2.4GHz band. :) Add an analog input or two, switchable by the same remote. Keep the wireless between the transmitter and receiver stations off of 2.4GHz too if you can.
Goosepond
  • Virna!
« Reply #18 on: 23 Nov 2010, 08:40 pm »
I've been trying to set up a PC audio system but can't take the first step because I don't want to go down all the false, expensive paths only to realize how to do it better. But you're description of a laptop with wireless connections to a DAC at my system is what I'm looking for, w/o the complications (for me) of a network (one step at a time  :thumb: ).
So count me interested.
And what is the next step as far as announcing/producing your product?
Gene
AirDAC
« Reply #19 on: 23 Nov 2010, 08:45 pm »
Thank you for your response however I am not sure if you understood the concept correctly. RF is not used for wireless transmission hence it's guaranteed free from RF interference.
Do you mean to put analog input(s) on the receiver or transmitter side of the system? I can not see the added value of analog inputs so please explain why this could be useful.
