0 Members and 1 Guest are viewing this topic. Read 1351 times.
The short answer is yes. You'll need to load the appropriate print drivers on each computer.
Has nothing to do with the Extreme. Just like a wired printer, you'd need to install drivers on any computer attached to it.
So when a guest comes over and wants to print they will have to install a driver?
Your guest can print to a pdf file and you can print that from your own system.
