0 Members and 2 Guests are viewing this topic. Read 138000 times.
Why don't you just try it? (I mean making it - a few feet of wire is all it takes. Isn't that the idea of having this in the Lab?)
Wind Chaser, I would strongly suggest that you obtain your tube amp before you make any decision on cables. They are the most susceptible to LCR differences among speaker cables.
I wonder if Cat 5e cable would work well since it has the teflon on each strand. Anyone?
Good idea, it might be interesting to compare single strands to all four pairs. And what about better quality wire like Wywire etc?
Serious. I'm a big believer in the difference cables can make, so it stands to reason why wouldn't they make a difference in this context?
While we're on this topic, anyone have a chemical recommendation to remove magnet wire coatings? I have tried epoxy paint stripper, lacquer thinner, acetone, and methanol to no avail. I'm probably going to try the aspirin trick as well but would like a nice hardy chemical to eat this stuff off. I'm not convinced the solder pot is going to be that effective.
Diet or regular?
