Bud, I have 30 and 36 ga magnet wire and a solder pot now. It appears I can melt the coating in the pot, clean off the burnt coating and expose copper and solder the wires together.How many loops of this size wire and what diameter should I start with?Should I then twist them together or leave them in an open loop?
Perhaps that would explain why you weren't impressed. When I tried CMR and CMG as speaker cable I couldn't understand what the fuss was all about. CMP has a very thin Plenum coating insulator which makes a very significant audible difference.
I had some CAT5e cable lying around with nothing to do, I made some single wire 20" loops and installed them on the negative speaker terminals.This could be in my head, but I really hear a considerable difference in the clarity, separation, and imaging. It sounds like there is a blacker (or quieter) background. Micro dynamics seem more obvious and I don't have to listen for details; they are just there. The sound stage also seems to have more depth as in sounds coming from near compared to farther away.
TJHUB, you are just suffering the exact same mass hypnosis the rest of us are suffering from, welcome home!Bud
That's exactly what I'm hearing too. What type of CAT 5 are you using?
I have tried several wires and they all make a difference, some good some not so good.
....... 16 ga stranded automotive type, red insulation .........Each loop is 12 in. total. Stripped about 1 1/2" from each end and twisted the ends together.
I can't believe this thread is serious. Why no one is objecting?
