0 Members and 2 Guests are viewing this topic. Read 138004 times.
So, an 8 step plan to get you into the poor house. And if you have a home theater system, well, our first Ground Plain product will be an even greater enticement than are the Ground Controls.Bud
This question is not for nor is it against and is asked out of well meant curiosity. Seriously, I've been curious as well regarding the EVS Ground Enhancers and will either try it via the diy recipe route or pick up a couple of pairs.Am curious about another aspect - that is how much of a role we are playing in this?I know I'm going down the psycho-acoustic rabbit-hole, but nontheless....curious about what those of you have used them would say, in case you have wondered the same?
Satfrat.Yes, that is what I have in my system, though I do have an extra pair on the plate amps running my sub woofer boxes. By the way, remember my mention of Planet 10 Hi Fi? My entire speaker system is from them, so I wasn't just being kind to a friend. Their finished goods are exceptional and they will sell you pre cut kits for the boxes and treated drivers to go in them. We are talking superior to world class sound.http://www.planet10-hifi.com/Bud
What are your thoughts on Cat 5e wire for this?
Do you recommend RCA grounds to be used as pairs, say right/left analog verses just using 1 per component?
Could there be any correlation between GE efficacy and impedance?
Have to congratulate and recognize BudP for the time and energy he has put in explaining this tweak, the details offered and the direct help with the diy approach.Hope some of us following this thread (myself included) support him with some purchases of his commercial tweak or other products he may have on offer, now and in the future.I do not see anywhere near the support from the the other 'mind blowing' purveyor in this regard on that thread, yet there seem to be a number of purchases of that tweak.Just saying... - support has value.Thanks Bud.- David.
David,Thanks for the clarification. So in essence there are 3 avenues to this technology.- The first being through Bud, the innovator who has done all the work and R&D who also markets his own product.- The second approach is through a competitor who may or may not be affiliated with Bud.- The third approach being DIY.Considering the significance / effectiveness of this tweak, I’d say it’s only fair that Bud receives some form of compensation.
So would a higher impedance yield a more substantial dividend?
"the result is a suddenly murky and dulled sound." and that was exactly what I experienced. Evidently too much Litz in the system ?
Assuming this is true Litz, where every strand is insulated from every other by a VERY thin coating (you want what is called "single build" coating) and no additional insulation on or within an inch of the wire, then yes, and cut the amount of wire by 1/3 in length, assuming you had 6 inches in a loop to begin with.Bud
Nope, no affiliation, but as far as I know, no animosity either. In fact, I am planning that our first Ground Plain product be one that can be matched with our esteemed competitors product, to provide something quite special.Bud
