0 Members and 1 Guest are viewing this topic. Read 11365 times.
There is no strict definition of low vs. high efficiency loudspeakers, but if one were to make some approximate classifications, one might say that 82dB - 86dB is low sensitivity, 87dB - 91dB is medium sensitivity, 92dB - 96dB is high sensitivity and 97dB and up is very high sensitivity. A speaker that is 3dB less sensitive requires twice the power to produce the same volume level, and one that is 3dB more sensitive requires half the power to produce the same volume level. Average listening levels often don't require more than a handful of watts, but when the music encounters large dynamic peaks, they could require 20 or 30 times the instantaneous power. It depends upon the recording, as many recordings are compressed to limit dynamic range so that they will sound decent on a large variety of systems. But if the amplifier can't supply the power required for the peaks, the top of the waveforms are cut off or "clipped" in most solid state amps (NAD has a circuit that reduces power and they call it "soft clipping") which results in distortion and harshness, and can potentially damage speakers, particularly tweeters. Tube amplifiers by nature have "soft clipping" and although they may have higher distortion specifications than solid state amps, the harmonics produced by overdriving are not as unpleasant or damaging. Your 88dB sensitive speakers are medium efficiency and as mentioned, wouldn't require enormous amounts of power, but their maximum sound level capability will also be ultimately governed by the physics of the 3" woofers, cabinet size, voice coil power handling capability and maximum cone excursion. But I still think you can realize an improvement with a quality amp of higher power than what you currently have. Steve
What say you about this NAD amp? Looks good:http://cgi.audiogon.com/cgi-bin/cl.pl?ampstran&1294329779
