0 Members and 1 Guest are viewing this topic. Read 194769 times.
Hey guys - Been following this thread since the start and have a question.I just got my EVS GE yesterday. I have added them to my front three channelsin my HT setup. No downside for me, larger soundstage, tighter bass and betterdimensionality - all right out of the box.My surround speakers are flush wall mounted. To add a GE to the negative postI would have to bend the GE itself to accomodate the installation. Has anyone done this? Does bending the body of the GE cause any negative effects?
I too shall take them off your hands for a copy of the Isotek System Enhancer & Rejuvenation Disc. Cheers,Robin
Certianly you don't mean copy... That is highly illegal.
Robin,I was wondering about issues with the antenna being pressed against the wall behind the speaker and the body of the GE not remaining straightSounds like it is a non issue as you have your GE against a video rack.thanks,Bill
Gopher, a little late to the parade but if anyone backs out, I too shall take them off your hands for a copy of the Isotek System Enhancer & Rejuvenation Disc. I run the Rejuvenation track each day myself and I do believe it to do as advertised.
Would have loved to do it locally but I committed to a west coaster. I can't imagine why it would matter, but is there any reason NOT to just rip the flacs and run 'em from Squeezebox. Lossless is lossless, I imagine and I'm not really setup for CD in my system. I guess I could run it on my PS3 and send an optical out to my DAC, but thats a PITA. I ripped my entire CD library to avoid physical media.If that is a fine solution, I'll probably do as you do and run the rejuv. track daily--whether it makes a difference or not, I may as well as my tubes warm up.
The Isotek I run daily is on HD and I found no differences myself between the HD and my actual Isotek CD,,, other than convenience. I was just thowing my hat in the ring anyways, fwiw. Cheers,Robin
Here's my experience with them.Have one on each speaker negative post and one on each negative post on the amp. Well, these things are pretty damn special.I first tried them just on the speakers, and I noticed greater air and separation right away. Vocals were crystal clear, but possibly too crisp and a little thin. I then ran through some tracks and then put one on each negative post on the amp. Wow, this hit the spot. It seemed to give more ass to my low-end, like really clean bass. The slight brightness seemed to be gone and everything was in more balance now. Still have the awesome separation and air in the instruments. Midrange, mid-bass and low-bass are very solid. Sounds like my SoundScapes can go even deeper now. Have had the system running over night and when I sat down today for a listening session, it was one of the best I've had. They're keepers.Seems like the magic really started when putting them on the amps, so I recommend trying the amp and the speakers. I didn't really need to damp them since they were usually up against something anyway, but I did tie one down and never had an issue with ringing. I previously moved my speakers away from the front and side walls, and lost some of my bass impact, but it seems like I got the bass back and more, without even moving the speakers.I have a few extra so I am going to put them on my surrounds. Great tweak!
Question. Do you have your Soundscapes biamped? There seems to be a lot of problems from guys who have tried these while biamping so I'm naturally curious how you have yours connected. Thanks. Cheers,Robin
Nope, not running them biamped. I have the enhancers on the un-used terminals on the speakers.
