Sherwood Newcastle P-965
0 Members and 1 Guest are viewing this topic. Read 2852 times.
John Casler
« on: 7 Mar 2004, 06:34 pm »
For those looking for a reasonably priced Pre/Pro, the Sherwood NewCastle P-965 has just hit the market.
I recently aquired one and if first impressions are worth anything, it is a "winner"  :thumb:
I haven't heard anything under $4500 that beats it.
It lists for $1499 (and as always private "courtesy pricing" for AC members)
I think one of the reasons for its great sound quality is that it retains the full power supply, that is used in its "sister" receiver the R965 which has 7 channel amps to supply.
I ran a film the other night and the "immersive" soundfield presented was the best I have heard.  A few rainy scenes and the sonic perception of being "surrounded" by pouring rain was incredibly lifelike.
And the most impressive quality was that of 3-D depth!! :o
So if you are looking for a Pre/pro that won't break the bank and gives you most all the bells ans whistles in a quality performance package, this might be worth a look/listen.
http://www.sherwoodusa.com/prod_p965.html
jgubman
« Reply #1 on: 8 Mar 2004, 06:19 pm »
You carry the Sherwood, huh? You're quickly becoming the one-stop shopping place!
How are the DACs in the sherwood? Sound ok in 2 channel?
I assume it has analog bypass, is it on all channels or just the 6-channel output?
Also, what's the bass management like on the 965? Is it a global crossover, or is it adjustable for fronts/center/surrounds?
thanks John
John Casler
« Reply #2 on: 9 Mar 2004, 02:04 am »
Quote from: jgubman
thanks John
Hey Jon,
Well I do have a lot of products, but I usually go after a line for some specific item and Sherwood Newcastle has a couple of those.
I'm still exploring the unit and will check on the things you ask about.
It does sound good in 2 channel and does have analog "direct".
And it has 7.1 inputs and 2 LFE outs.
More, as I have time to discover it.
John Casler
« Reply #3 on: 10 Mar 2004, 12:52 am »
Jon,
Here is how the Bass Management looks:
Crossover frequencies are global and can be set to 40/60/80/100/120 Hz. 4th order low pass filters. 2nd order high pass.
jgubman
« Reply #4 on: 10 Mar 2004, 12:58 am »
Hmmm, that's kind of a bummer, guess I could use the global x/o for the center & surrounds, set the fronts to large and use the NHT X1 or the marchard x/o to cross the fronts at 40hz and the others at either 80 or 60...
It upsamples to 192/24 right? Have you tried that out?
Also, have you tested the phono section at all?
Sorry for all the questions, but this unit might be a next upgrade!
Rob Babcock
« Reply #5 on: 10 Mar 2004, 01:34 am »
Can a DSP soundfield (eg PLII) be applied in conjunction with the upsampling feature?
John Casler
« Reply #6 on: 10 Mar 2004, 01:39 am »
Quote from: jgubman
If you are doing a dual system with VMPS speakers, the X-over would be the NHT X2.
The X1 is for NHT speakers only.  (has their special equalization curve)
While I am quite happy with mine I haven't run any mains "low passed" out of it yet to see if it affects the sound at all.  It sure works great as a "highpass filter" for my Larger though, and it also allows the LFE channel to be used without cable switching :mrgreen:
Haven't had a chance to do the 192/24 thing yet, but this is on non-planar Tower II's so we'll see what it sounds like.
And I have my doubts as to if I'll actually get a TT hooked up to it, but I do have a spare one. :mrgreen:   Denon direct drive w/Dynavector Karat Ruby cart.
Brian Bunge
« Reply #7 on: 11 Mar 2004, 01:48 am »
John,
I'm a huge Newcastle fan!  I haven't had the privelege to hear the P-965 yet but am dying to do so.  My dad and I have only used Newcastle receivers for the last 5 years or so and we have no desire to switch to another name brand.
BTW, I hope you don't my posting in your thread.  I just wanted to sing the praises of the Newcastle products.
