Amp for Unifield 2 (High n Mid Channel)
0 Members and 1 Guest are viewing this topic. Read 1759 times.
earlgrey
« on: 3 Nov 2010, 06:44 am »
Hi everyone,
I'm looking for a amp for my Unifield 2's High n Mid Channel, which means I'm going to bi-amp. Any recommendation.
My current setup is: Source to Audio Research LS26 pre and output thru Pass Lab X350.5 and to Unifield 2
Will like to get more fluid and sweeter High n Mid, therefore thinking of bi-amping. Presently there's a option for me, a First Watt F5, any comments? Will I have a problem with the gain difference?
Cheers :D
ceedee
    • Musical Reality
Re: Amp for Unifield 2 (High n Mid Channel)
« Reply #1 on: 3 Nov 2010, 07:47 am »
Hello Earlgrey,
Bi-amping is possible but why do you want this?
When your room is not that big you can easily get more fluid by using a KR tube amp.
Look and listen to the link below.
This KR VA 340 is a 25 watt KR 300B amplifier driving the Uni II.
The soundtrack is a CD played by the system and recorded by a set of AKG 300b condenser microphones connected to the camera.
http://www.youtube.com/watch?v=c2tN5FVSeTs
The problem you expect with bi-amping is the match between both amps.
You also can go for a KR VA 320 on top and the pass on the botom.
You can always tune your gain of the LS26 into your system.
Good Luck,
Cor
earlgrey
« Reply #2 on: 3 Nov 2010, 08:16 am »
Reason is that I really like the low freq produce by 350.5, I don't know if my LS26 can adjust individual input gain so that's part of my worry..
ceedee
    • Musical Reality
« Reply #3 on: 3 Nov 2010, 11:35 am »
You only have adjust the LS 26 output to match the both amps.
