Tube Hiss
0 Members and 1 Guest are viewing this topic. Read 1902 times.
catastrofe
  • "That's what credit cards are for. . ."
Tube Hiss
« on: 29 Oct 2010, 07:55 pm »
My tube pre has too much hiss for my liking.  My current speakers are 90db efficent, but they are being replaced by Salk SS10s at about 85db efficiency.
Will/should the reduction in efficiency reduce the hiss?
avahifi
    • http://www.avahifi.com
Re: Tube Hiss
« Reply #1 on: 29 Oct 2010, 08:16 pm »
Yes, the level of your hiss will go down 5 dB with the wonderful Soundscapes.  It may even go down more than that if your present speakers had a response peak in the "hiss" range.  A less efficient speaker means a better single to noise ratio.  The noise from your preamp is a constant, now you will have to feed out more signal so the signal to noise ratio will improve.
Congratulations on the Soundscapes.  I wish I could afford them.
Frank Van Alstine
catastrofe
Re: Tube Hiss
« Reply #2 on: 29 Oct 2010, 08:29 pm »
Frank Van Alstine
Thanks Frank.  I wish I could afford them too!!!   :green:
iGrant
Re: Tube Hiss
« Reply #3 on: 31 Oct 2010, 02:48 pm »
umm, your hiss will stay the same or go up is my thinking as you crank the pre more to overcome the 5db loss in a speaker swap to stay at your listening level. Are you sure it is the pre that is the cause of the hiss?
Ian
catastrofe
Re: Tube Hiss
« Reply #4 on: 31 Oct 2010, 03:09 pm »
Yes, Ian, the hiss is definitely from my pre and it doesn't change with gain.  I'm inclined to think it will be reduced with lower sensitivity speakers.  I guess I'll find out soon enough!  :D
