0 Members and 21 Guests are viewing this topic. Read 3662138 times.
rockadanny
« Reply #21460 on: 25 Feb 2022, 04:24 pm »
Thelonious Monk - Criss-Cross
Lee Konitz - Motion
GerryD
« Reply #21461 on: 25 Feb 2022, 08:27 pm »
mresseguie
« Reply #21462 on: 25 Feb 2022, 09:35 pm »
How do I insert the album/CD cover photo?
I discovered this CD on Tidal while I was searching for another Brooklyn group. "Brooklyn Jazz Quartet" is the group, and there is just one CD on Tidal. I llike this music!
Merryvale92
« Reply #21463 on: 26 Feb 2022, 05:34 am »
S Clark
« Reply #21464 on: 26 Feb 2022, 05:44 am »
This one??
I looked them up on YouTube.  The vocalist has a real Billy Holiday sound.
https://www.youtube.com/watch?v=K8Hjlr8V35s
GerryD
« Reply #21465 on: 26 Feb 2022, 07:53 pm »
Yog Sothoth
« Reply #21466 on: 26 Feb 2022, 10:04 pm »
I've been really enjoying this album.  Big bang, Latin, exotica.  Very fun.
mresseguie
« Reply #21467 on: 26 Feb 2022, 11:40 pm »
This one??
Yes. This is the one. There are some Christmas songs that this group performed, but there don’t seem to be any other CDs.
rockadanny
« Reply #21468 on: 27 Feb 2022, 08:07 pm »
Art Pepper - Road Game (live)
Thelonious Monk - Big Band and Quartet in Concert
Hiromi - Spark
Tired of the same ol' same ol' when it comes to jazz piano trios? Check THIS out! Phenomenal modern jazz music, playing, and charts.
GerryD
« Reply #21469 on: 27 Feb 2022, 09:12 pm »
Jeff_From_Michigan
« Reply #21470 on: 28 Feb 2022, 02:58 pm »
Thanks to Merryvale92 for the rec on another thread!
« Reply #21471 on: 28 Feb 2022, 11:59 pm »
          Terje Rypdal:      What Comes After      '73
« Reply #21472 on: 1 Mar 2022, 12:27 am »
Michael, it varies a little depending on browser & location of the pic. First do a "quote" on any posting with a pic to see what it (the core post) looks like. The "insert image" box is the first on the left of the lower row of buttons above the emojies in the posting section. You'll likely want two window/tabs open. Start a post, go to your image source, Amazon, allmusic, Discogs, etc., find the album image, right-click on the image, in the flyout select "copy image link" (or address), return to your Post, left click the image button, then copy/past from memory (the image location you selected earlier). Note the cursor needs to be between the middle brackets [img] here [/...], then do a "Preview" to see result. Typical image size you see posted is 500x500 pix, most Amazon images are that but larger images of 1200x & larger can be edited down to 500x simply by changing that characteristic in the image address. Discogs images are usually 600x, not sure about the streaming service images. Keeping the image to 500x keeps it easily visible on smaller screens. I'm sure you've see some of the larger pics which add scroll bars to bottom & side to view the whole thing, making them very inconvenient, and impossible to view in total. Or you can copy an image to your computer, then upload it to AC, then select that address to insert from.
Hope that helps, if not PM me I'll try to clarify.
Cheers.........JD
Yog Sothoth
« Reply #21474 on: 1 Mar 2022, 12:36 am »
I was intrigued by this posting by @GerryD, so I've ordered a copy.  It sounds very interesting!
« Reply #21475 on: 2 Mar 2022, 08:06 pm »
Tejre Rypdal • Odyssey
« Reply #21476 on: 3 Mar 2022, 01:08 am »
Classic stuff Pman, doesn't get any better !   :thumb: :thumb: :thumb:
« Reply #21477 on: 3 Mar 2022, 03:46 am »
        Herbie Hancock:    Inventions & Dimensions       '64
« Reply #21478 on: 3 Mar 2022, 04:26 am »
          Wayne Shorter:    JuJu    '65
GerryD
« Reply #21479 on: 4 Mar 2022, 08:38 pm »
