0 Members and 1 Guest are viewing this topic. Read 19135 times.
Got a box of WyWires yesterday, will start sampling them later today.
OK - between getting taxes done and family dropping in enroute home to BOS from FL, I've not touched the box. Today I'm home alone, so time to begin.Opened the box, looks like 3 PCs, they'll all be going in, and a pair of ICs w/rca terminations.Unfortunatly, I can't make make use of the balanced cables, and the speaker cables are too short for my needs, but maybe I'll push speakers over at end to give 'em a try.
Hi Alex -Yes, I've been derelict, between starting a new job this past Monday and finishing taxes last night, I hadn't turned on my system from last Sunday night till last night.To date, I've run through my phono setup, and was half way through SACD testing up to last Sunday night. This weekend I'll finish up SACD and CD testing, and post the results.Gene
Finished testing SACD player, CD player next.There's a chance one of the 2 shorter PCs not working, I put it into SACD player, 1st time I've tried the 2nd shorter PC, and no power. Swapped it with the other shorter PC still in phono-pre, have power in SACD player now, but not phono-pre.Tomorrow I'll take them both to bench to test further, my phono-pre is finicky about the way the PC sits in the IEC, but SACD has never been an issue before.GeneGene
Well, would it be easier to just wait to send it to next person and I send the bad one back to you?Gene
Quite frankly, I've just been moving the one from piece to piece. My amp has a hardwired cord, so that's outside my changing.But, maybe you should send me a replacement just so I can add it to the package so next person gets the complete set.G.
Yes sir!
