0 Members and 1 Guest are viewing this topic. Read 15217 times.
Btw, are there any good guides out there for sub tuning / setup? This is my first sub with parametric eq so looking for tips on that esp. I have setup discs and radioshack spl meter that I use to setup my system.
I wonder if your listening position or speaker placement is causing a null below 60Hz, as you should be hearing the extended depth of the ST's
I noticed you had an Onkyo receiver. Are you using Audyssey to calibrate the system? If so, try turning it off. Also, try listening to music in the "Direct" mode if you have not already done so.- Jim
It just sounds like the B&W port tuning is warmer.
Dennis, maybe it is just me, but please explain it for those who do not design crossovers for Salk Sound
It just sounds like the B&W port tuning is warmer. I'm pretty sure the ST's are voiced flat in that region. As for whistling noises--I have no idea. Unless it's port noise--I forget--what kind of signal are you feeding them, and at how high a level?
I wasn't trying to be technical. If I were, I would have talked about "Q"values. All I was suggesting is that the box may be tuned to emphasize the midbass a bit--hence "warm" or "full" sound. It's very common in bass reflex designs.
Ah, I see. Another basic q - does that change the frequency response from flat, or are the two unrelated?
Just for the record, when Paul Kittinger designed the SongTower TL cabinet (using Martin King's matcad formulas), his goal was to produce the most accurate response along with the deepest bass extension possible from the drivers. He did not tune the cabinet to produce an artificially "warm" or "full" response. The goal was accuracy.- Jim
