What Did You Have Before The N3?
0 Members and 1 Guest are viewing this topic. Read 1363 times.
jeffx
« on: 24 Oct 2010, 03:25 pm »
I am considering building the N3. However, I have never heard the N3 so I am trying to get a feel for its overall sound.
What did you own before you built the N3 or the N2X? Is there another speaker that you can compare/contrast its performance to?
Thanks for your help!
Ron
Re: What Did You Have Before The N3?
« Reply #1 on: 24 Oct 2010, 10:15 pm »
 Compared to the AV-3, the N3 is has a more open, detailed, and transparent midrange and high end. The N2X has a very similar sound quality to the N3, but the N3 and the N3S are more efficient, have a wider dynamic range, and better power handling capability. I have built and sold a number of N2X and the N3S. They are both wonderful sounding speakers, but I like the N3 and N3S better. If your budget allows, I highly recommend going with all the performance upgrade options including the Sonicap Platinum bypass capacitors. Presently building a pair of N3S and N2X speakers in natural cherry veneer to sell.
