0 Members and 1 Guest are viewing this topic. Read 41847 times.
JT....had a look at that link. I see where you can eliminate(ignore) scripts for file sections eg. photos or Tunes, but don't see where you can have the backup ignore previously backed up files unless this is a default feature ? I had thought Darrel did NOT recommend Super Duper for our audio file backup. I do see SD would be best for OS HD backup, in which case you could have this operation "ignore" ITunes or AIFF files or whatever. All of this is probably super (uber) easy, but I find all these nuances to be daunting. Another tough one to grasp is, backing up your MAC HD along side your "music" files on the same external backup drive. If we want this "bootable" to make restoration easy, is it best to keep the audio "music" files on a separate drive ? Many many questions I'm not sure are appropriate for this thread, but drives do seem to be the "life blood" to our Mach2 Server !
Also, in our tests, piping music in via ethernet (from another Mac, not a RAID) didn't sounds as good as via the Firewire 800 with a good sounding HD/enclosure. In comparison, the ethernet sounded compressed and flat. I know others swear by ethernet so don't go strictly by my limited testing. I would actually like to hear from others who have done A/B test between ethernet and firewire.
I gotta think even 24/192 files can handle 100mbit.
